Philco 91 Dial Scale
It seems that the station frequency is not showing correctly on the dial scale of my Philco 91. When I am tuned into a station on 1260 the dial scale pointer is around 1360. I do not see a way of adjusting the dial scale since it is rivited to a large pulley that is fastened to the variable capacitor. Would an alignment fix this?
Charlie
Philco 91 Dial Scale - by cwirth - 12-05-2013, 08:29 AM
RE: Philco 91 Dial Scale - by jerryhawthorne - 12-05-2013, 02:12 PM
There are currently 10389 online users. [Complete List]
» 2 Member(s) | 10387 Guest(s)
