Philco 42-365
http://www.philcoradio.com/gallery/1942a.htm
Not a real common set...but not a desirable one, either, from a collectibility standpoint. I have one like yours, either a 42-365 or 360, don't really remember right now. It was given to me by a good friend...I do not plan to restore it, but will use it for parts. Its cabinet is pretty much shot.
Do replace those electrolytics, and ALL paper capacitors as well. The old rubber insulation on the wiring will also have to be addressed.
Good luck, and enjoy!
Philco 42-365 - by Guest - 05-02-2008, 08:50 PM
[No subject] - by Ron Ramirez - 05-04-2008, 11:31 AM
There are currently 10357 online users. [Complete List]
» 2 Member(s) | 10355 Guest(s)
