Philco 40-130 with Lousy Reception
In most locations now-a-days, electrical noise due to hi-frequency switching power supplies and HID lighting is so bad on the old AM band, that good antennas and sensitive radios buy nothing. If your old Philco can receive what a hand-held transistor set can, that's all you can ordinarily expect.
Philco 40-130 with Lousy Reception - by PT57 - 12-08-2013, 04:16 PM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-08-2013, 04:17 PM
RE: Philco 40-130 with Lousy Reception - by Bill Kinghorn - 12-08-2013, 05:19 PM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-08-2013, 05:36 PM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-08-2013, 11:55 PM
RE: Philco 40-130 with Lousy Reception - by Arran - 12-09-2013, 01:15 AM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-09-2013, 07:50 PM
RE: Philco 40-130 with Lousy Reception - by Jamie - 12-10-2013, 10:06 AM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-10-2013, 12:02 PM
RE: Philco 40-130 with Lousy Reception - by Jayce - 12-10-2013, 03:40 PM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-10-2013, 07:28 PM
RE: Philco 40-130 with Lousy Reception - by morzh - 12-11-2013, 12:48 PM
RE: Philco 40-130 with Lousy Reception - by PT57 - 12-11-2013, 12:59 PM
RE: Philco 40-130 with Lousy Reception - by morzh - 12-11-2013, 01:22 PM
RE: Philco 40-130 with Lousy Reception - by morzh - 12-11-2013, 02:21 PM
RE: Philco 40-130 with Lousy Reception - by marv - 12-11-2013, 04:47 PM
There are currently 3528 online users. [Complete List]
» 2 Member(s) | 3526 Guest(s)
