Craigslist 40-190
Sorry Murf, radio and chassis are restored! I'm sure you will find a suitable chassis somewhere. Good luck!
Kevin
Craigslist 40-190 - by 37silverstreak - 07-27-2013, 08:29 PM
RE: Craigslist 40-190 - by NostalgiaRadioTime - 07-27-2013, 10:25 PM
RE: Craigslist 40-190 - by Ron Ramirez - 07-28-2013, 07:30 AM
RE: Craigslist 40-190 - by Arran - 07-28-2013, 08:26 AM
RE: Craigslist 40-190 - by marty - 07-28-2013, 09:09 AM
RE: Craigslist 40-190 - by 37silverstreak - 07-28-2013, 10:59 AM
RE: Craigslist 40-190 - by murf - 12-08-2013, 02:02 PM
RE: Craigslist 40-190 - by 37silverstreak - 12-08-2013, 06:24 PM
Philco 91 Tuning Condenser
