Looking for correct grommets 40-201
I am trying to determine what rubber grommets are the correct ones for the tuning capacitor mounting on the 40-195/200/201. I see a couple of them on http://www.renovatedradios.com/parts.html that look right but there are two different ones listed: GPH-RFTR and GPH-49-900. Unfortunately there is not enough information on all the dimensions of both of these to determine if they will work with the 1940 models.
Also for the push-button bracket there are two rubber grommets that could be correct: GPH-46-480 and GLg-Tuner. Can anyone help me nail down which ones to order?
I sent a query to Renovated Radios, but it has been days ago and I have not received a response from them. Perhaps they cannot determine and/or do not have enough data on their grommets to determine which ones would work.
Thanks in advance.
Joe
Looking for correct grommets 40-201 - by Joeztech - 12-09-2013, 10:10 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
