39-6ci
Hi
Can't help you with side views, but I can tell you that the sides and top are also ivory, as is the front (note: ivory, not white).
Trim is black, as you noted.
Hope this helps.
39-6ci - by philco phan - 05-07-2008, 09:05 PM
[No subject] - by Ron Ramirez - 05-07-2008, 10:06 PM
[No subject] - by philco phan - 05-08-2008, 12:49 AM
[No subject] - by Ron Ramirez - 05-08-2008, 06:45 AM
Eico 232 VTVM Schematic
There are currently 7551 online users. [Complete List]
» 1 Member(s) | 7550 Guest(s)
