37-670 dial question
Thank you for the response. Yes they are different. I think the 37-2670 has long wave and one less shortwave band.
Looks like an original could be difficult to find so I may end up getting a repro dial.
37-670 dial question - by thirtiesradio - 12-02-2013, 04:01 AM
RE: 37-670 dial question - by TA Forbes - 12-04-2013, 09:34 PM
RE: 37-670 dial question - by thirtiesradio - 12-10-2013, 04:33 AM
There are currently 10121 online users. [Complete List]
» 3 Member(s) | 10118 Guest(s)
