emerson
thanks Brenda schematic is lot clearer then mine
had solar tubular cap in it for mica one, 500k resistor blown, 3 caps melted out and had 60 and 90 electrolytic`s in it had to replace all tubes and caps temp replaced resister actually worked great pulled in several stations none of my radios did that yet good for 2hr watched never went above 115 v then fuse in veriac blew well ill put right parts in and repair speaker mine thumb keeps poking holes in it so I will need to fine one
chuck I like yours always liked wood but don't want to work with it
thanks for your help sam
emerson - by sam - 12-08-2013, 07:00 PM
RE: emerson - by morzh - 12-08-2013, 07:57 PM
RE: emerson - by BrendaAnnD - 12-08-2013, 11:15 PM
RE: emerson - by codefox1 - 12-09-2013, 03:59 PM
RE: emerson - by Chuck Schwark - 12-09-2013, 04:29 PM
RE: emerson - by sam - 12-10-2013, 02:22 PM
RE: emerson - by Chuck Schwark - 12-10-2013, 02:39 PM
