42-321 questions
Good morning, all
An update with some questions:
I installed the new switch after shaping the shaft with a file to make the knob fit. The switch works like a charm, and I now have a working radio that receives well all along the band. Installing it was much easier than I thought it would be.
Does anyone have a dial cord installation diagram for this unit?
Also, what the correct size dial light? Did the original look like a night light bulb?
Thanks, Terry
42-321 questions - by ke5yum - 11-14-2013, 09:20 AM
RE: 42-321 questions - by klondike98 - 11-14-2013, 08:18 PM
RE: 42-321 questions - by morzh - 11-15-2013, 12:00 AM
RE: 42-321 questions - by ke5yum - 11-19-2013, 09:20 AM
RE: 42-321 questions - by morzh - 11-19-2013, 02:39 PM
RE: 42-321 questions - by ke5yum - 11-20-2013, 08:56 AM
RE: 42-321 questions - by codefox1 - 11-20-2013, 04:35 PM
RE: 42-321 questions - by ke5yum - 11-26-2013, 08:51 AM
RE: 42-321 questions - by vinzer - 11-26-2013, 12:44 PM
RE: 42-321 questions - by ke5yum - 12-11-2013, 09:06 AM
RE: 42-321 questions - by klondike98 - 12-11-2013, 10:43 AM
RE: 42-321 questions - by ke5yum - 12-11-2013, 11:20 AM
There are currently 4998 online users. [Complete List]
» 1 Member(s) | 4997 Guest(s)
