630 power transformer question.....
Hi Guys.....
On the bench as I write is the power transformer of a Philco 630. The original transformer has died and went to flux heaven. The replacement, a known good transformer (so far), needed the usual new extension leads and a trip to the painting booth.
What I need to know before installation is the idle current draw on the AC primary side of the transformer. Hooked up at 117 VAC, I'm seeing a draw of 160 ma. (+/- 10 ma.)
Is this number in the ballpark? Unlike new transformers, I know the efficiencies of these older units can vary quite a bit and before I go about installing this one, I'd like to get a handle on whether or not the transformer will be a good candidate.
All ruminations welcome...
...Jim
630 power transformer question..... - by Jim Koehler - 12-11-2013, 01:20 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
There are currently 3737 online users. [Complete List]
» 2 Member(s) | 3735 Guest(s)
