Philco 37-640 questions.
ok thats good to know, one thing, the on off knob has a 4th position so it is off on tone and ?
what do these tone positions do? I cant seem to get any radio stations to come in, thanks for the prior info.
Kirk L
Philco 37-640 questions. - by OldRestorer - 12-11-2013, 06:49 PM
RE: Philco 37-640 questions. - by Ron Ramirez - 12-11-2013, 06:56 PM
RE: Philco 37-640 questions. - by OldRestorer - 12-11-2013, 09:32 PM
RE: Philco 37-640 questions. - by Ron Ramirez - 12-11-2013, 09:36 PM
RE: Philco 37-640 questions. - by Warren - 12-11-2013, 10:15 PM
RE: Philco 37-640 questions. - by OldRestorer - 12-12-2013, 07:57 AM
RE: Philco 37-640 questions. - by OldRestorer - 12-12-2013, 08:13 AM
RE: Philco 37-640 questions. - by klondike98 - 12-12-2013, 11:14 AM
RE: Philco 37-640 questions. - by OldRestorer - 12-12-2013, 11:39 AM
RE: Philco 37-640 questions. - by klondike98 - 12-12-2013, 11:58 AM
RE: Philco 37-640 questions. - by Arran - 12-12-2013, 10:25 PM
RE: Philco 37-640 questions. - by klondike98 - 12-12-2013, 11:19 PM
RE: Philco 37-640 questions. - by OldRestorer - 12-13-2013, 07:44 AM
Philco 91 Tuning Condenser
There are currently 9432 online users. [Complete List]
» 1 Member(s) | 9431 Guest(s)
