  • 1 Vote(s) - 5 Average
Starting work on my 19B
1) It IS a personal preference. I used to repot mine with a hot glue gun. Others, including myself now, don't bother to repot them.
2) The "HUGE" resistors are generally 2-3 watts.
Starting work on my 19B - by PAradiogeek - 12-06-2013, 12:16 AM
RE: Starting work on my 19B - by BrendaAnnD - 12-06-2013, 06:49 AM
RE: Starting work on my 19B - by Mondial - 12-06-2013, 08:35 AM
RE: Starting work on my 19B - by PAradiogeek - 12-06-2013, 11:44 AM
RE: Starting work on my 19B - by PAradiogeek - 12-11-2013, 10:02 PM
RE: Starting work on my 19B - by BrendaAnnD - 12-11-2013, 10:28 PM
RE: Starting work on my 19B - by PAradiogeek - 12-12-2013, 02:49 PM
RE: Starting work on my 19B - by BrendaAnnD - 12-12-2013, 03:19 PM
RE: Starting work on my 19B - by codefox1 - 12-12-2013, 08:20 PM
RE: Starting work on my 19B - by morzh - 12-12-2013, 11:41 PM
RE: Starting work on my 19B - by PAradiogeek - 12-13-2013, 08:34 AM
RE: Starting work on my 19B - by jerryhawthorne - 12-13-2013, 07:48 PM
RE: Starting work on my 19B - by klondike98 - 12-13-2013, 07:59 PM
RE: Starting work on my 19B - by Radioroslyn - 12-15-2013, 12:53 PM
RE: Starting work on my 19B - by PAradiogeek - 12-15-2013, 09:37 PM
RE: Starting work on my 19B - by jerryhawthorne - 12-15-2013, 10:11 PM
RE: Starting work on my 19B - by PAradiogeek - 12-16-2013, 08:55 PM
RE: Starting work on my 19B - by PAradiogeek - 12-19-2013, 11:30 PM
RE: Starting work on my 19B - by klondike98 - 12-19-2013, 11:50 PM
RE: Starting work on my 19B - by Bradley Rush - 12-20-2013, 03:44 AM
RE: Starting work on my 19B - by PAradiogeek - 12-20-2013, 08:11 AM
RE: Starting work on my 19B - by jerryhawthorne - 12-20-2013, 06:16 PM
RE: Starting work on my 19B - by PAradiogeek - 12-25-2013, 04:40 PM
RE: Starting work on my 19B - by Ron Ramirez - 12-25-2013, 06:02 PM
RE: Starting work on my 19B - by morzh - 12-25-2013, 06:08 PM
RE: Starting work on my 19B - by PAradiogeek - 12-25-2013, 07:49 PM
RE: Starting work on my 19B - by morzh - 12-25-2013, 09:39 PM
RE: Starting work on my 19B - by PAradiogeek - 12-25-2013, 11:53 PM
RE: Starting work on my 19B - by tab10672 - 12-26-2013, 12:43 AM
RE: Starting work on my 19B - by morzh - 12-26-2013, 11:24 AM
RE: Starting work on my 19B - by PAradiogeek - 12-26-2013, 03:18 PM
RE: Starting work on my 19B - by PAradiogeek - 01-11-2014, 06:04 PM
RE: Starting work on my 19B - by PAradiogeek - 01-13-2014, 08:34 AM
RE: Starting work on my 19B - by PAradiogeek - 02-16-2014, 12:03 AM
RE: Starting work on my 19B - by morzh - 02-16-2014, 12:13 PM
RE: Starting work on my 19B - by PAradiogeek - 03-03-2014, 11:37 PM
RE: Starting work on my 19B - by PAradiogeek - 03-07-2014, 11:47 PM
RE: Starting work on my 19B - by Mondial - 03-08-2014, 12:00 AM
RE: Starting work on my 19B - by PAradiogeek - 03-19-2014, 09:20 PM
RE: Starting work on my 19B - by skyscraper - 03-19-2014, 09:38 PM
RE: Starting work on my 19B - by Mondial - 03-19-2014, 09:49 PM
RE: Starting work on my 19B - by skyscraper - 03-19-2014, 09:56 PM
RE: Starting work on my 19B - by Joeztech - 03-20-2014, 07:46 AM
RE: Starting work on my 19B - by PAradiogeek - 03-21-2014, 11:47 PM
RE: Starting work on my 19B - by jerryhawthorne - 03-22-2014, 12:35 AM
RE: Starting work on my 19B - by Joeztech - 03-22-2014, 06:50 AM
RE: Starting work on my 19B - by Mondial - 03-22-2014, 10:34 AM
RE: Starting work on my 19B - by Joeztech - 03-22-2014, 11:12 AM
RE: Starting work on my 19B - by PAradiogeek - 03-24-2014, 10:25 PM
RE: Starting work on my 19B - by skyscraper - 03-24-2014, 10:41 PM
RE: Starting work on my 19B - by PAradiogeek - 03-25-2014, 07:13 AM
RE: Starting work on my 19B - by morzh - 03-25-2014, 10:12 AM
RE: Starting work on my 19B - by Radioroslyn - 03-25-2014, 05:10 PM
RE: Starting work on my 19B - by PAradiogeek - 03-25-2014, 08:14 PM
RE: Starting work on my 19B - by PAradiogeek - 03-25-2014, 11:42 PM
RE: Starting work on my 19B - by skyscraper - 03-26-2014, 12:17 AM
RE: Starting work on my 19B - by PAradiogeek - 03-30-2014, 07:34 AM
RE: Starting work on my 19B - by Steve Davis - 03-30-2014, 08:57 AM
RE: Starting work on my 19B - by PAradiogeek - 03-30-2014, 11:21 AM
RE: Starting work on my 19B - by skyscraper - 03-30-2014, 12:32 PM
RE: Starting work on my 19B - by PAradiogeek - 03-30-2014, 04:50 PM
There are currently 10594 online users. [Complete List]
» 4 Member(s) | 10590 Guest(s)
AvatarAvatarAvatarAvatar
