need help naming this
Or it possibly uses a pair of 71As, #50s, or 2A3s, but it could be #45s. The set somewhat resembles a Stromberg Carlson, they liked to use tuning meters in some of their sets.
need help naming this - by sam - 12-11-2013, 11:07 PM
RE: need help naming this - by Jayce - 12-11-2013, 11:16 PM
RE: need help naming this - by Mondial - 12-11-2013, 11:44 PM
RE: need help naming this - by Arran - 12-12-2013, 01:54 AM
RE: need help naming this - by TA Forbes - 12-12-2013, 02:02 PM
RE: need help naming this - by jerryhawthorne - 12-12-2013, 05:39 PM
RE: need help naming this - by Joe Rossi - 12-12-2013, 08:58 PM
RE: need help naming this - by sam - 12-14-2013, 05:37 PM
RE: need help naming this - by Joe Rossi - 12-14-2013, 07:07 PM
RE: need help naming this - by sam - 12-14-2013, 08:36 PM
RE: need help naming this - by Arran - 12-15-2013, 01:19 AM
RE: need help naming this - by Joe Rossi - 12-16-2013, 09:21 PM
RE: need help naming this - by Mondial - 12-16-2013, 09:48 PM
RE: need help naming this - by BrendaAnnD - 12-16-2013, 11:34 PM
RE: need help naming this - by Mondial - 12-17-2013, 12:17 AM
RE: need help naming this - by sam - 12-18-2013, 01:41 PM
RE: need help naming this - by BrendaAnnD - 12-18-2013, 03:12 PM
RE: need help naming this - by jerryhawthorne - 12-18-2013, 05:16 PM
RE: need help naming this - by sam - 12-22-2013, 01:39 AM
