Philco 37-640 questions.
Thanks for the info and I know what you are going to say, Dont turn on the radio until the capacitors are replaced. I have not learned to do this yet so i have not. I do have a 6' wire antenna connected but which screw? first is red, second is black, third is ground and 4 is unmarked.sorry to ask when you answered but i am no good with stage right or left....
As for the next questions: I need chassis training, I have been looking all over the getting started pages and found a few books for beginners but not sure which one is best for a complete novice.
Any suggestions or does anyone have one to sell me? Ill post it in wanted ads but i want to see what one to request.
1. Antique Radio Restoration Guide
2. Elements of Radio Servicing
3. The Radio Amateur's Handbook
4. Old Time Radios! Restoration and Repair
5. How to Repair Old-Time Radios
thanks all,
Kirk L
Philco 37-640 questions. - by OldRestorer - 12-11-2013, 06:49 PM
RE: Philco 37-640 questions. - by Ron Ramirez - 12-11-2013, 06:56 PM
RE: Philco 37-640 questions. - by OldRestorer - 12-11-2013, 09:32 PM
RE: Philco 37-640 questions. - by Ron Ramirez - 12-11-2013, 09:36 PM
RE: Philco 37-640 questions. - by Warren - 12-11-2013, 10:15 PM
RE: Philco 37-640 questions. - by OldRestorer - 12-12-2013, 07:57 AM
RE: Philco 37-640 questions. - by OldRestorer - 12-12-2013, 08:13 AM
RE: Philco 37-640 questions. - by klondike98 - 12-12-2013, 11:14 AM
RE: Philco 37-640 questions. - by OldRestorer - 12-12-2013, 11:39 AM
RE: Philco 37-640 questions. - by klondike98 - 12-12-2013, 11:58 AM
RE: Philco 37-640 questions. - by Arran - 12-12-2013, 10:25 PM
RE: Philco 37-640 questions. - by klondike98 - 12-12-2013, 11:19 PM
RE: Philco 37-640 questions. - by OldRestorer - 12-13-2013, 07:44 AM
Philco 91 Tuning Condenser
