  • 1 Vote(s) - 5 Average
Starting work on my 19B
Thanks Brenda.
The guy I bought this radio from had tried to get it working, but he was not successful. There is a sticker on the back of the chassis that says the rectifier caps were replaced in Feb. 2003. What are the chances that they are still good after sitting on the shelf, unpowered, for the last ~11 years? I'm fine with replacing them again, but I only want to do that if all you experts think this is a good idea.
Jon
Starting work on my 19B - by PAradiogeek - 12-06-2013, 12:16 AM
RE: Starting work on my 19B - by BrendaAnnD - 12-06-2013, 06:49 AM
RE: Starting work on my 19B - by Mondial - 12-06-2013, 08:35 AM
RE: Starting work on my 19B - by PAradiogeek - 12-06-2013, 11:44 AM
RE: Starting work on my 19B - by PAradiogeek - 12-11-2013, 10:02 PM
RE: Starting work on my 19B - by BrendaAnnD - 12-11-2013, 10:28 PM
RE: Starting work on my 19B - by PAradiogeek - 12-12-2013, 02:49 PM
RE: Starting work on my 19B - by BrendaAnnD - 12-12-2013, 03:19 PM
RE: Starting work on my 19B - by codefox1 - 12-12-2013, 08:20 PM
RE: Starting work on my 19B - by morzh - 12-12-2013, 11:41 PM
RE: Starting work on my 19B - by PAradiogeek - 12-13-2013, 08:34 AM
RE: Starting work on my 19B - by jerryhawthorne - 12-13-2013, 07:48 PM
RE: Starting work on my 19B - by klondike98 - 12-13-2013, 07:59 PM
RE: Starting work on my 19B - by Radioroslyn - 12-15-2013, 12:53 PM
RE: Starting work on my 19B - by PAradiogeek - 12-15-2013, 09:37 PM
RE: Starting work on my 19B - by jerryhawthorne - 12-15-2013, 10:11 PM
RE: Starting work on my 19B - by PAradiogeek - 12-16-2013, 08:55 PM
RE: Starting work on my 19B - by PAradiogeek - 12-19-2013, 11:30 PM
RE: Starting work on my 19B - by klondike98 - 12-19-2013, 11:50 PM
RE: Starting work on my 19B - by Bradley Rush - 12-20-2013, 03:44 AM
RE: Starting work on my 19B - by PAradiogeek - 12-20-2013, 08:11 AM
RE: Starting work on my 19B - by jerryhawthorne - 12-20-2013, 06:16 PM
RE: Starting work on my 19B - by PAradiogeek - 12-25-2013, 04:40 PM
RE: Starting work on my 19B - by Ron Ramirez - 12-25-2013, 06:02 PM
RE: Starting work on my 19B - by morzh - 12-25-2013, 06:08 PM
RE: Starting work on my 19B - by PAradiogeek - 12-25-2013, 07:49 PM
RE: Starting work on my 19B - by morzh - 12-25-2013, 09:39 PM
RE: Starting work on my 19B - by PAradiogeek - 12-25-2013, 11:53 PM
RE: Starting work on my 19B - by tab10672 - 12-26-2013, 12:43 AM
RE: Starting work on my 19B - by morzh - 12-26-2013, 11:24 AM
RE: Starting work on my 19B - by PAradiogeek - 12-26-2013, 03:18 PM
RE: Starting work on my 19B - by PAradiogeek - 01-11-2014, 06:04 PM
RE: Starting work on my 19B - by PAradiogeek - 01-13-2014, 08:34 AM
RE: Starting work on my 19B - by PAradiogeek - 02-16-2014, 12:03 AM
RE: Starting work on my 19B - by morzh - 02-16-2014, 12:13 PM
RE: Starting work on my 19B - by PAradiogeek - 03-03-2014, 11:37 PM
RE: Starting work on my 19B - by PAradiogeek - 03-07-2014, 11:47 PM
RE: Starting work on my 19B - by Mondial - 03-08-2014, 12:00 AM
RE: Starting work on my 19B - by PAradiogeek - 03-19-2014, 09:20 PM
RE: Starting work on my 19B - by skyscraper - 03-19-2014, 09:38 PM
RE: Starting work on my 19B - by Mondial - 03-19-2014, 09:49 PM
RE: Starting work on my 19B - by skyscraper - 03-19-2014, 09:56 PM
RE: Starting work on my 19B - by Joeztech - 03-20-2014, 07:46 AM
RE: Starting work on my 19B - by PAradiogeek - 03-21-2014, 11:47 PM
RE: Starting work on my 19B - by jerryhawthorne - 03-22-2014, 12:35 AM
RE: Starting work on my 19B - by Joeztech - 03-22-2014, 06:50 AM
RE: Starting work on my 19B - by Mondial - 03-22-2014, 10:34 AM
RE: Starting work on my 19B - by Joeztech - 03-22-2014, 11:12 AM
RE: Starting work on my 19B - by PAradiogeek - 03-24-2014, 10:25 PM
RE: Starting work on my 19B - by skyscraper - 03-24-2014, 10:41 PM
RE: Starting work on my 19B - by PAradiogeek - 03-25-2014, 07:13 AM
RE: Starting work on my 19B - by morzh - 03-25-2014, 10:12 AM
RE: Starting work on my 19B - by Radioroslyn - 03-25-2014, 05:10 PM
RE: Starting work on my 19B - by PAradiogeek - 03-25-2014, 08:14 PM
RE: Starting work on my 19B - by PAradiogeek - 03-25-2014, 11:42 PM
RE: Starting work on my 19B - by skyscraper - 03-26-2014, 12:17 AM
RE: Starting work on my 19B - by PAradiogeek - 03-30-2014, 07:34 AM
RE: Starting work on my 19B - by Steve Davis - 03-30-2014, 08:57 AM
RE: Starting work on my 19B - by PAradiogeek - 03-30-2014, 11:21 AM
RE: Starting work on my 19B - by skyscraper - 03-30-2014, 12:32 PM
RE: Starting work on my 19B - by PAradiogeek - 03-30-2014, 04:50 PM
Users browsing this thread: 18 Guest(s)
