  • 1 Vote(s) - 1 Average
Want To Purchase A Isolation Transfomer
I am setting up my workbench and am looking for an isolation transformer. Was wondering if anyone had any recommendations? I see that some brands like the Tripp may have to be modified I would prefer one that is a true isolation transformer.
Charlie
Want To Purchase A Isolation Transfomer - by cwirth - 12-13-2013, 12:08 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3493 online users. [Complete List]
» 2 Member(s) | 3491 Guest(s)
