  • 1 Vote(s) - 1 Average
Want To Purchase A Isolation Transfomer
I have been reading that the Tripp isolation transformers may need the ground disconnected from the output outlet. So if the Tripp was a true isolation transformer wouldn't this have been done?
RE: Want To Purchase A Isolation Transfomer - by cwirth - 12-13-2013, 12:48 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3474 online users. [Complete List]
» 1 Member(s) | 3473 Guest(s)
