RESISTOR ID 38-15 philco help
Thx
The color coding threw me off its banded. Not dots but that would make the color code correct for 17
thx Vinzer
RESISTOR ID 38-15 philco help - by Bradley Rush - 12-13-2013, 04:50 AM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 12:49 PM
RE: RESISTOR ID 38-15 philco help - by Bradley Rush - 12-13-2013, 04:13 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 04:16 PM
RE: RESISTOR ID 38-15 philco help - by morzh - 12-13-2013, 05:11 PM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 06:34 PM
RE: RESISTOR ID 38-15 philco help - by BrendaAnnD - 12-13-2013, 08:12 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 09:05 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 10:38 PM
RE: RESISTOR ID 38-15 philco help - by David - 01-08-2014, 07:21 PM
There are currently 8868 online users. [Complete List]
» 2 Member(s) | 8866 Guest(s)
