Letter Tube Numbers XXL vs. 7A4 etc
vinyltocdr@msn.com Wrote:since the FM in those early 40's sets can be very difficult, finiky, and problematic, i would like to keep the tubes as original as possible to rule out any varations.
I hope you are aware that the FM band on the pre-war sets no longer exists!
Letter Tube Numbers XXL vs. 7A4 etc - by Guest - 05-11-2008, 01:52 AM
Re: Letter Tube Numbers XXL vs. 7A4 etc - by exray - 05-11-2008, 08:20 AM
[No subject] - by Guest - 05-11-2008, 12:37 PM
[No subject] - by Ron Ramirez - 05-11-2008, 02:46 PM
[No subject] - by Guest - 05-11-2008, 07:25 PM
[No subject] - by exray - 05-11-2008, 10:28 PM
[No subject] - by BDM - 05-11-2008, 10:36 PM
[No subject] - by Texasrocker - 05-12-2008, 01:55 AM
[No subject] - by Fred R - 05-13-2008, 07:01 PM
Philco 91 Tuning Condenser
