RESISTOR ID 38-15 philco help
I think Mondial is right I thought it was the agc resistor but after looking again its on the wrong end of the volume control for that.
RESISTOR ID 38-15 philco help - by Bradley Rush - 12-13-2013, 04:50 AM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 12:49 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 04:16 PM
RE: RESISTOR ID 38-15 philco help - by morzh - 12-13-2013, 05:11 PM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 06:34 PM
RE: RESISTOR ID 38-15 philco help - by BrendaAnnD - 12-13-2013, 08:12 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 09:05 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 10:38 PM
RE: RESISTOR ID 38-15 philco help - by David - 01-08-2014, 07:21 PM
There are currently 9360 online users. [Complete List]
» 2 Member(s) | 9358 Guest(s)
