Ready for 41-290 upgrade
Yes, I got your order Keith - thanks. Like Ron says, the info packet you'll get has a fully annotated schematic (parts values and tube pin voltages) and an underside chassis parts placement diagram, Production change notes, as well as a dial cord stringing diagram, parts listing alignment instructions and pushbutton alignment info.
And Happy Turkey to you. Icon_smile
Ready for 41-290 upgrade - by madghost - 11-23-2005, 06:37 PM
[No subject] - by Ron Ramirez - 11-23-2005, 11:45 PM
READING SCHEMATICS - by madghost - 11-24-2005, 02:07 PM
[No subject] - by Ron Ramirez - 11-24-2005, 02:18 PM
[No subject] - by Chuck Schwark - 11-24-2005, 09:37 PM
tv input - by Guest - 12-14-2005, 08:12 PM
There are currently 4767 online users. [Complete List]
» 1 Member(s) | 4766 Guest(s)
