Chevron Grill Cloth
Ken,
The only reason I ordered the cloth from Radio Daze is that it appears lighter in color and I wanted to do a side by side comparison with yours. Also, I have a couple of 1938 sets that need grill cloth and while the Radio Daze cloth isn't the correct pattern, I thought the lighter color might work better than the darker 1935-37 pattern you carry.
Don't take my comparison as a question of the quality of your product. I've already ordered 2 pieces of yours and will more than likely order more. Thank you so much for taking the time to have such an accurate reproduction made!
Chevron Grill Cloth - by PAradiogeek - 10-18-2013, 11:31 PM
RE: Chevron Grill Cloth - by klondike98 - 10-18-2013, 11:57 PM
RE: Chevron Grill Cloth - by Geoff - 10-19-2013, 03:36 PM
RE: Chevron Grill Cloth - by jontz - 12-12-2013, 08:37 AM
RE: Chevron Grill Cloth - by Ron Ramirez - 12-12-2013, 11:24 AM
RE: Chevron Grill Cloth - by jontz - 12-12-2013, 11:51 AM
RE: Chevron Grill Cloth - by Geoff - 12-12-2013, 09:31 PM
RE: Chevron Grill Cloth - by Ron Ramirez - 12-12-2013, 09:41 PM
RE: Chevron Grill Cloth - by jontz - 12-13-2013, 07:38 AM
RE: Chevron Grill Cloth - by Geoff - 12-13-2013, 04:49 PM
RE: Chevron Grill Cloth - by Geoff - 12-13-2013, 07:02 PM
RE: Chevron Grill Cloth - by jontz - 12-13-2013, 09:37 PM
RE: Chevron Grill Cloth - by Richmond Designs - 12-14-2013, 12:56 AM
RE: Chevron Grill Cloth - by bfrohwein - 12-14-2013, 01:52 AM
RE: Chevron Grill Cloth - by jontz - 12-14-2013, 12:20 PM
RE: Chevron Grill Cloth - by Geoff - 12-14-2013, 01:14 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
