  • 1 Vote(s) - 1 Average
Want To Purchase A Isolation Transfomer
Fuse does not affect whatever potential, even the zapping one. All it will do is blow upon overloading. Even a 100mA fuse will kill you with the same success rate as a 100A one.
Fuses are there to protect against fire, mostly.
RE: Want To Purchase A Isolation Transfomer - by morzh - 12-14-2013, 03:39 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3489 online users. [Complete List]
» 2 Member(s) | 3487 Guest(s)
