Speaker Field Coil Question
Looking to verify the DC Ohms of the Following Speakers
CATHEDRAL MODELS
Model 51 Philco 6 inch Speaker FIELD 2500 DC Ohms ??????
Model 80 Philco 6 Inch Speaker FIELD 1200 DC Ohms ???????
Would like to verify above readings on a know speaker.
Thanks
Bob T
Speaker Field Coil Question - by joybird - 12-14-2013, 05:58 PM
RE: Speaker Field Coil Question - by Ron Ramirez - 12-14-2013, 07:51 PM
RE: Speaker Field Coil Question - by joybird - 12-14-2013, 08:33 PM
Philco 91 Tuning Condenser
