RESISTOR ID 38-15 philco help
Yes - the changes to the 38-15 2nd detector circuit are documented, and you can find this plus all known production changes to 1933-1938 Philco sets here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Look for the file changes.zip .
RESISTOR ID 38-15 philco help - by Bradley Rush - 12-13-2013, 04:50 AM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 12:49 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 04:16 PM
RE: RESISTOR ID 38-15 philco help - by morzh - 12-13-2013, 05:11 PM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 06:34 PM
RE: RESISTOR ID 38-15 philco help - by BrendaAnnD - 12-13-2013, 08:12 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 09:05 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 10:38 PM
RE: RESISTOR ID 38-15 philco help - by Ron Ramirez - 12-14-2013, 07:59 PM
RE: RESISTOR ID 38-15 philco help - by David - 01-08-2014, 07:21 PM
Philco 91 Tuning Condenser
There are currently 8750 online users. [Complete List]
» 2 Member(s) | 8748 Guest(s)
