Speaker Field Coil Question
Hi Ron
Thank You, that is good news as yes that was my intent .
I have a 551 someone put a 2500 Ohm Coil Speaker in.
Merry Christmas
Bob T
Speaker Field Coil Question - by joybird - 12-14-2013, 05:58 PM
RE: Speaker Field Coil Question - by Ron Ramirez - 12-14-2013, 07:51 PM
RE: Speaker Field Coil Question - by joybird - 12-14-2013, 08:33 PM
Philco 91 Tuning Condenser
There are currently 9775 online users. [Complete List]
» 1 Member(s) | 9774 Guest(s)
