  • 1 Vote(s) - 5 Average
Gassy 80 Rectifier Tube
OK, thanks for the advice. I do have some other 80 tubes around here but they are the ST type not the globe type as the gassy one is. I was hoping to use the globe type but sounds like it's best not to use gassy tubes.
I am doing a side experiment where I'm running the gassy tube on a lab power supply on about half filament voltage. I'll let it go several days and then check to see if the blue glow is still there when it's in the radio.
Don't know if you're supposed to run plate current for this fix or not. Will start with just half filament current for now.
Herb
Gassy 80 Rectifier Tube - by hsusmann - 12-15-2013, 03:46 PM
RE: Gassy 80 Rectifier Tube - by codefox1 - 12-15-2013, 08:28 PM
RE: Gassy 80 Rectifier Tube - by morzh - 12-15-2013, 08:32 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-15-2013, 10:54 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-15-2013, 11:17 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-15-2013, 11:21 PM
RE: Gassy 80 Rectifier Tube - by codefox1 - 12-17-2013, 04:20 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-17-2013, 06:23 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-17-2013, 11:07 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-18-2013, 12:10 AM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-18-2013, 09:17 AM
RE: Gassy 80 Rectifier Tube - by PAradiogeek - 12-19-2013, 11:39 AM
RE: Gassy 80 Rectifier Tube - by jontz - 12-19-2013, 11:47 AM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-19-2013, 12:15 PM
RE: Gassy 80 Rectifier Tube - by Ron Ramirez - 12-19-2013, 12:37 PM
RE: Gassy 80 Rectifier Tube - by jontz - 12-19-2013, 01:29 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-19-2013, 03:07 PM
RE: Gassy 80 Rectifier Tube - by codefox1 - 12-19-2013, 06:04 PM
RE: Gassy 80 Rectifier Tube - by PAradiogeek - 12-19-2013, 08:59 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-19-2013, 09:35 PM
RE: Gassy 80 Rectifier Tube - by Chuck Schwark - 12-19-2013, 11:26 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-20-2013, 12:01 AM
RE: Gassy 80 Rectifier Tube - by BrendaAnnD - 12-20-2013, 12:55 AM
RE: Gassy 80 Rectifier Tube - by Mondial - 12-20-2013, 09:12 AM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-20-2013, 09:28 AM
RE: Gassy 80 Rectifier Tube - by Joeztech - 12-20-2013, 09:35 AM
RE: Gassy 80 Rectifier Tube - by Mondial - 12-20-2013, 09:45 AM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-20-2013, 11:47 AM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-20-2013, 12:27 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-20-2013, 02:35 PM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
91H Code 126 Restore
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4580 online users. [Complete List]
» 1 Member(s) | 4579 Guest(s)
