509X-anyone have one with pictures ?
I have this radio on my bucket list. EDIT- I meant a 509X. Thank you Gene for the correction.
One sold on ebay a few years ago for way more than I was willing to bid at the time. That is the only one I have ever seen.I believe it used the same Hi-Fi chassis as the 201X console.
Anyone here have one, seen one in person or have photos of one to share ?
509X-anyone have one with pictures ? - by y2kbruce - 12-16-2013, 08:18 AM
Philco 91 Tuning Condenser
There are currently 10430 online users. [Complete List]
» 2 Member(s) | 10428 Guest(s)
