Philco "mystery control" part
Might be the battery pack clamp for the left side. There are two similar clamps on the right side which hold down the battery.
Philco "mystery control" part - by Art Hoch - 12-16-2013, 08:01 PM
RE: Philco "mystery control" part - by Mondial - 12-16-2013, 09:33 PM
RE: Philco "mystery control" part - by Art Hoch - 12-18-2013, 01:29 PM
Philco 91 Tuning Condenser
There are currently 8558 online users. [Complete List]
» 2 Member(s) | 8556 Guest(s)
