Philco 42-365 Question on parts
the long metal component is probably a tapped resistor,check resistance from lug to lug.
Philco 42-365 Question on parts - by Guest - 05-12-2008, 10:56 AM
[No subject] - by Chuck Schwark - 05-12-2008, 02:43 PM
[No subject] - by philco phan - 05-13-2008, 09:42 PM
