LARGE Stewart Warner 9010A Tabletop
Found this on CL. Not the prettiest girl at the party, but a huge multiband tabletop that measures 27"W X 14.5"H X 12"D I'm OK with it for $40.
[Image: http://i1185.photobucket.com/albums/z345...c9f800.jpg]
[Image: http://i1185.photobucket.com/albums/z345...1b4589.jpg]
[Image: http://i1185.photobucket.com/albums/z345...d3179d.jpg]
[Image: http://i1185.photobucket.com/albums/z345...b00964.jpg]
[Image: http://i1185.photobucket.com/albums/z345...7f9036.jpg]
[Image: http://i1185.photobucket.com/albums/z345...e4c854.jpg]
Gene[/b]
LARGE Stewart Warner 9010A Tabletop - by Gene Pederson - 12-17-2013, 05:35 PM
There are currently 7155 online users. [Complete List]
» 2 Member(s) | 7153 Guest(s)
