40-201 Cabinet Stain Used
klondike98;
It seems that the Ultra Classic type would be more transparent and let the wood grain show through better. Thanks for that explanation about the difference between the Tone Finish and the Ultra Classic types and the link to the manufacturer information.
Joe
40-201 Cabinet Stain Used - by Joeztech - 12-17-2013, 08:21 AM
RE: 40-201 Cabinet Stain Used - by Ron Ramirez - 12-17-2013, 09:47 AM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-17-2013, 05:11 PM
RE: 40-201 Cabinet Stain Used - by klondike98 - 12-17-2013, 05:52 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-18-2013, 07:51 AM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-18-2013, 07:54 PM
RE: 40-201 Cabinet Stain Used - by Ron Ramirez - 12-18-2013, 08:45 PM
RE: 40-201 Cabinet Stain Used - by Steve Davis - 12-18-2013, 09:50 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-19-2013, 07:42 AM
RE: 40-201 Cabinet Stain Used - by Joeztech - 01-10-2014, 07:41 PM
RE: 40-201 Cabinet Stain Used - by Eric T - 01-10-2014, 08:22 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 01-11-2014, 09:13 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 01-11-2014, 09:16 PM
RE: 40-201 Cabinet Stain Used - by Arran - 01-12-2014, 04:59 AM
RE: 40-201 Cabinet Stain Used - by Ron Ramirez - 01-12-2014, 09:01 AM
RE: 40-201 Cabinet Stain Used - by OldRestorer - 01-17-2014, 11:06 AM
There are currently 7702 online users. [Complete List]
» 1 Member(s) | 7701 Guest(s)
