40-201 Chassis Rewiring
codefox1;
Yes I agree, red for B+. Philco seems to have used some yellow, some green and some red for the filaments and dial lamp leads. I like to use green for safety ground (if present), black or gray for AC, black for ground. Philco did seem to use some white and blue for IF transformer B+ so I stayed with what they originally used except for the B+ input where I did use red. The later convention on filaments that I saw in the 1950s was brown for filaments, so here I stayed consistent with that except for the dial lamp leads where I used pretty much the original colors as best I could tell. Many of the cloth jacketed wires are so faded and changed in color it is really hard to tell. The schematic is sometimes silent on the issue of color of wires.
I decided early on that I was not going to try to duplicate the cloth wiring as I was unable to find the types I wanted, so plastic insulation it is. Since the chassis is already painted and does not look original it did not make sense to me to go to elaborate lengths to try to keep a completely original look to everything under the chassis. Some people would want to and I have no problem with that.
I did some B+ wiring today and stopped to wait for one wire wound dropping resistor to make up for a lower resistance in the field core speaker compared to the original. I is only off about 60-80 ohms depending on which ohm meter I use. I ordered both values so I can try each one to see which gets closest to the voltage shown in the schematic.
Cheers!
Joe
40-201 Chassis Rewiring - by Joeztech - 12-17-2013, 05:01 PM
RE: 40-201 Chassis Rewiring - by codefox1 - 12-18-2013, 12:00 PM
RE: 40-201 Chassis Rewiring - by Joeztech - 12-18-2013, 02:46 PM
What should I offer?
I think you have a chance at purchasing a 48-1286, based on the cabinet hardware. Only 8700 were produced, so it is a r...GarySP — 02:28 PM
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
There are currently 3364 online users. [Complete List]
» 2 Member(s) | 3362 Guest(s)
