40-201 Cabinet Stain Used
I'm not sure what type wood Philco used for the "white wood" trim parts but, I mostly use poplar to make trim pieces. Poplar has a straight, close grain and is easily shaped with machines or hand tools. It is very similar in appearances to maple but softer. Lowe's and Home Depot both stock poplar.
M R Radios   C M Tubes
40-201 Cabinet Stain Used - by Joeztech - 12-17-2013, 08:21 AM
RE: 40-201 Cabinet Stain Used - by Ron Ramirez - 12-17-2013, 09:47 AM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-17-2013, 05:11 PM
RE: 40-201 Cabinet Stain Used - by klondike98 - 12-17-2013, 05:52 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-18-2013, 07:51 AM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-18-2013, 07:54 PM
RE: 40-201 Cabinet Stain Used - by Ron Ramirez - 12-18-2013, 08:45 PM
RE: 40-201 Cabinet Stain Used - by Steve Davis - 12-18-2013, 09:50 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 12-19-2013, 07:42 AM
RE: 40-201 Cabinet Stain Used - by Joeztech - 01-10-2014, 07:41 PM
RE: 40-201 Cabinet Stain Used - by Eric T - 01-10-2014, 08:22 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 01-11-2014, 09:13 PM
RE: 40-201 Cabinet Stain Used - by Joeztech - 01-11-2014, 09:16 PM
RE: 40-201 Cabinet Stain Used - by Arran - 01-12-2014, 04:59 AM
RE: 40-201 Cabinet Stain Used - by Ron Ramirez - 01-12-2014, 09:01 AM
RE: 40-201 Cabinet Stain Used - by OldRestorer - 01-17-2014, 11:06 AM
There are currently 4881 online users. [Complete List]
» 2 Member(s) | 4879 Guest(s)
