Electrolytic Capacitors
RON: Here's one for ya. I have a Philco chassis that was in a office building PA system. It had been a custom built outfit, with an RCA-furnished manual motor board.The reeceiver chassis was a modified Philco 91 set, and this is where it got interesting. There was a power amplifier with this set that used 2-81 rectifiers, and 2-50 outputs!
Have you ever known of Philco to use Push-pull 50 outputs? I never have. I have all of those pieces as I bought them, years ago at AWA in Canandaigua. At that time, even the 81's and the 50's were there. I've never fired up the chassis.
Electrolytic Capacitors - by Guest - 05-13-2008, 10:05 AM
[No subject] - by Chuck Schwark - 05-13-2008, 10:43 AM
[No subject] - by exray - 05-13-2008, 02:28 PM
[No subject] - by Chuck Schwark - 05-13-2008, 04:24 PM
Electrolytic Capacitors - by Guest - 05-13-2008, 06:22 PM
[No subject] - by Chuck Schwark - 05-13-2008, 09:01 PM
[No subject] - by Ron Ramirez - 05-13-2008, 09:25 PM
[No subject] - by Guest - 05-14-2008, 10:27 AM
[No subject] - by Ron Ramirez - 05-14-2008, 06:09 PM
[No subject] - by Guest - 05-15-2008, 07:42 AM
[No subject] - by Doug Houston - 05-15-2008, 11:00 PM
[No subject] - by Ron Ramirez - 05-16-2008, 06:52 AM
There are currently 5761 online users. [Complete List]
» 2 Member(s) | 5759 Guest(s)
