  • 1 Vote(s) - 5 Average
Gassy 80 Rectifier Tube
Yes, any visible blue or violet glow between the elements is an indication of a gassy rectifier. All vacuum tubes have some residual gas, so it is a matter of degree and whether it affects the tube function.
A rectifier tube is not particularly sensitive to the gas until it gets to the point where it may arc or affects the emission by damage to the cathode. I have a feeling this is why your globe 80 tests low, as its cathode emission has been reduced by the gas ion bombardment over a long period of time.
Its a different story with tubes having control grids, where even a small amount of gas can result in positive grid current, which throws off the bias conditions and can result in excessive plate current.
Gassy 80 Rectifier Tube - by hsusmann - 12-15-2013, 03:46 PM
RE: Gassy 80 Rectifier Tube - by codefox1 - 12-15-2013, 08:28 PM
RE: Gassy 80 Rectifier Tube - by morzh - 12-15-2013, 08:32 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-15-2013, 10:54 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-15-2013, 11:17 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-15-2013, 11:21 PM
RE: Gassy 80 Rectifier Tube - by codefox1 - 12-17-2013, 04:20 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-17-2013, 06:23 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-17-2013, 11:07 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-18-2013, 12:10 AM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-18-2013, 09:17 AM
RE: Gassy 80 Rectifier Tube - by PAradiogeek - 12-19-2013, 11:39 AM
RE: Gassy 80 Rectifier Tube - by jontz - 12-19-2013, 11:47 AM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-19-2013, 12:15 PM
RE: Gassy 80 Rectifier Tube - by Ron Ramirez - 12-19-2013, 12:37 PM
RE: Gassy 80 Rectifier Tube - by jontz - 12-19-2013, 01:29 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-19-2013, 03:07 PM
RE: Gassy 80 Rectifier Tube - by codefox1 - 12-19-2013, 06:04 PM
RE: Gassy 80 Rectifier Tube - by PAradiogeek - 12-19-2013, 08:59 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-19-2013, 09:35 PM
RE: Gassy 80 Rectifier Tube - by Chuck Schwark - 12-19-2013, 11:26 PM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-20-2013, 12:01 AM
RE: Gassy 80 Rectifier Tube - by BrendaAnnD - 12-20-2013, 12:55 AM
RE: Gassy 80 Rectifier Tube - by Mondial - 12-20-2013, 09:12 AM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-20-2013, 09:28 AM
RE: Gassy 80 Rectifier Tube - by Joeztech - 12-20-2013, 09:35 AM
RE: Gassy 80 Rectifier Tube - by Mondial - 12-20-2013, 09:45 AM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-20-2013, 11:47 AM
RE: Gassy 80 Rectifier Tube - by hsusmann - 12-20-2013, 12:27 PM
RE: Gassy 80 Rectifier Tube - by Phlogiston - 12-20-2013, 02:35 PM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
91H Code 126 Restore
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4649 online users. [Complete List]
» 3 Member(s) | 4646 Guest(s)
