Philco 640 Cabinet Refinishing Chronicles
Here are some photos of the new decal:
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=2]
I also started filling in the small pits in the top corner that I mentioned in a previous post. This happened when I was removing tape. Here is what it looked like originally:
I'm spraying lacquer from the can into the plastic spray can cap and using a fine artist brush to place a small drop of lacquer in each pit. It's been below 65F in my garage so I spray it into the cap out there and then bring it inside to apply. Some of the bigger pits will take multiple applications to build it back up again. Looks like it won't be warm enough to spray again until Sunday. Stay tuned.
RE: Philco 640 Cabinet Refinishing Chronicles - by Geoff - 12-20-2013, 01:24 PM
Users browsing this thread: 44 Guest(s)
Philco 91 Tuning Condenser
There are currently 10194 online users. [Complete List]
» 3 Member(s) | 10191 Guest(s)
