City: Sedona, AZ/Placentia/CA
Just my approach on those pesky cans in Philcos.
Jerry
getting it out with a bolt and using it as a slide hammer. Nice to have the cardboard cover as it keeps things from sticking.
[Image: http://i303.photobucket.com/albums/nn129...0004-6.jpg]
Jerry
RE: Starting work on my 19B - by jerryhawthorne - 12-20-2013, 06:16 PM
Users browsing this thread: 19 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
