BV-613 various questions
Hi
Just been checking frequencies, with the design above it is 78Hz, this compares favourably with my simulation (84Hz). I must have misread my initial measurement. Thanks for the information on Mallory vibrators (will make good Christmas reading), after a bit of playing with values, my model shows a that if the two 820 Ohm resistors are changed to 620 Ohms then the frequency should be 118Hz, after a quick mod a frequency of 102Hz was measured.
Will have to make a few more checks as current is a tad high, time to check for more leaky caps (need to check the single can that holds 4 paper caps). More to follow after the Christmas break
Cheers
Richard
BV-613 various questions - by 64EK26 - 11-08-2013, 01:49 PM
RE: BV-613 various questions - by BrendaAnnD - 11-08-2013, 03:33 PM
RE: BV-613 various questions - by 64EK26 - 11-08-2013, 06:27 PM
RE: BV-613 various questions - by BrendaAnnD - 11-08-2013, 07:19 PM
RE: BV-611 restoration - by 64EK26 - 12-19-2013, 03:38 PM
RE: BV-613 various questions - by codefox1 - 12-19-2013, 06:09 PM
RE: BV-613 various questions - by Mondial - 12-19-2013, 10:36 PM
RE: BV-613 various questions - by 64EK26 - 12-20-2013, 01:50 PM
RE: BV-613 various questions - by morzh - 12-20-2013, 02:41 PM
RE: BV-613 various questions - by 64EK26 - 12-20-2013, 04:04 PM
RE: BV-613 various questions - by Mondial - 12-20-2013, 06:03 PM
RE: BV-613 various questions - by 64EK26 - 12-21-2013, 04:15 PM
RE: BV-613 various questions - by Mondial - 12-21-2013, 08:17 PM
RE: BV-613 various questions - by klondike98 - 08-19-2017, 10:45 AM
RE: BV-613 various questions - by Radioroslyn - 08-19-2017, 12:03 PM
RE: BV-613 various questions - by Cesardeluxe - 10-14-2018, 04:03 PM
RE: BV-613 various questions - by Cesardeluxe - 11-05-2018, 07:26 AM
RE: BV-613 various questions - by klondike98 - 11-05-2018, 08:58 AM
RE: BV-613 various questions - by Radioroslyn - 11-05-2018, 12:42 PM
91H Code 126 Restore
