Threads: 562
Thanks, Scott.
Well, my chassis had been messed with quite a bit. It's a good thing it was not "re-designed" like someone had it here not so long ago.....
Will see. I hope to finish major works end of this week and then I will have to see what the story is with the speaker and if it had given the previous "repairman" a reason to do what he did with the chassis (though I absolutely would not do that).
RE: 90 restoration - by morzh - 12-23-2013, 05:35 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
