My Christmas Present - 118MX
Hey Jamie, do you have a higher res version of the 118 under-chassis photo? I am working on the same chassis and it would be useful as a reference of a relatively untouched original.
My Christmas Present - 118MX - by Jamie - 12-21-2013, 08:46 PM
RE: My Christmas Present - 118MX - by sam - 12-21-2013, 08:51 PM
RE: My Christmas Present - 118MX - by Jamie - 12-21-2013, 08:55 PM
RE: My Christmas Present - 118MX - by sam - 12-21-2013, 09:09 PM
RE: My Christmas Present - 118MX - by Jayce - 12-21-2013, 09:18 PM
RE: My Christmas Present - 118MX - by Arran - 12-21-2013, 09:41 PM
RE: My Christmas Present - 118MX - by Ron Ramirez - 12-21-2013, 10:17 PM
RE: My Christmas Present - 118MX - by Jamie - 12-22-2013, 03:12 PM
RE: My Christmas Present - 118MX - by sam - 12-22-2013, 04:23 PM
RE: My Christmas Present - 118MX - by Ron Ramirez - 12-22-2013, 07:54 PM
RE: My Christmas Present - 118MX - by Groundhog74 - 12-22-2013, 09:20 PM
RE: My Christmas Present - 118MX - by TA Forbes - 12-22-2013, 09:57 PM
RE: My Christmas Present - 118MX - by Jamie - 12-23-2013, 11:51 AM
RE: My Christmas Present - 118MX - by Mondial - 12-23-2013, 06:44 PM
RE: My Christmas Present - 118MX - by Jamie - 12-23-2013, 07:51 PM
RE: My Christmas Present - 118MX - by Joeztech - 12-23-2013, 07:53 PM
RE: My Christmas Present - 118MX - by KCMike - 12-23-2013, 08:12 PM
RE: My Christmas Present - 118MX - by Jamie - 12-23-2013, 11:12 PM
RE: My Christmas Present - 118MX - by Arran - 12-24-2013, 02:04 AM
RE: My Christmas Present - 118MX - by EricS - 12-26-2013, 09:10 PM
RE: My Christmas Present - 118MX - by Jamie - 01-08-2014, 04:47 PM
RE: My Christmas Present - 118MX - by gregb - 01-08-2014, 06:34 PM
RE: My Christmas Present - 118MX - by Jamie - 01-08-2014, 07:09 PM
RE: My Christmas Present - 118MX - by gregb - 01-08-2014, 09:14 PM
RE: My Christmas Present - 118MX - by gregb - 01-08-2014, 10:57 PM
RE: My Christmas Present - 118MX - by Jamie - 01-09-2014, 03:33 PM
RE: My Christmas Present - 118MX - by gregb - 01-09-2014, 03:40 PM
RE: My Christmas Present - 118MX - by Jamie - 01-09-2014, 06:00 PM
RE: My Christmas Present - 118MX - by vinzer - 01-09-2014, 08:08 PM
Philco 91 Tuning Condenser
