What to use for dial cord springs
I found that the 40-201 radio I acquired did not have its dial cord tension springs. I have it working using some springs from ball-point pens for now, but the tension is not as tight as it should be. Have any of you found a good source of springs to use for dial cord tensioning?
Joe
What to use for dial cord springs - by Joeztech - 12-23-2013, 08:20 PM
RE: What to use for dial cord springs - by jontz - 12-23-2013, 09:25 PM
Philco 91 Tuning Condenser
