40-201 now has power
Jontz;
Yes I painted the chassis. It began with a mouse nest infested chassis, many wires chewed into etc. See this thread in the same Phorum: http://www.philcoradio.com/phorum/showth...p?tid=7984 (Preparing 40-201 for painting chassis)
It shows pictures of the before appearance of the unit. It took removal of all the top of chassis parts, scrubbing with gojo that had pumice in it and a wire brush, some Naval jelly, some sanding followed by masking and gray primer, then the brushed satin nickle Krylon paint that Ron recommends. It was a time consuming effort. My son-in-law was amazed when he saw the results recently.
Joe
40-201 now has power - by Joeztech - 12-23-2013, 03:45 PM
RE: 40-201 now has power - by jerryhawthorne - 12-23-2013, 04:27 PM
RE: 40-201 now has power - by Joeztech - 12-23-2013, 06:45 PM
RE: 40-201 now has power - by jerryhawthorne - 12-23-2013, 07:13 PM
RE: 40-201 now has power - by Joeztech - 12-23-2013, 08:08 PM
RE: 40-201 now has power - by codefox1 - 12-23-2013, 08:56 PM
RE: 40-201 now has power - by jontz - 12-23-2013, 09:33 PM
RE: 40-201 now has power - by Paul Philco322 - 12-23-2013, 11:11 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 07:33 AM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 07:45 AM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 10:14 AM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 04:53 PM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 05:53 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 08:03 PM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 08:53 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 10:54 PM
RE: 40-201 now has power - by Radioroslyn - 12-25-2013, 11:15 AM
RE: 40-201 now has power - by Joeztech - 12-25-2013, 03:34 PM
RE: 40-201 now has power - by BrendaAnnD - 12-25-2013, 06:47 PM
RE: 40-201 now has power - by Joeztech - 12-25-2013, 07:05 PM
RE: 40-201 now has power - by Joeztech - 12-26-2013, 08:15 AM
RE: 40-201 now has power - by hsusmann - 12-26-2013, 09:53 AM
RE: 40-201 now has power - by Joeztech - 12-26-2013, 11:48 AM
RE: 40-201 now has power - by hsusmann - 12-26-2013, 10:54 PM
RE: 40-201 now has power - by BrendaAnnD - 12-26-2013, 11:59 PM
RE: 40-201 now has power - by Eric Adams - 12-27-2013, 01:50 AM
RE: 40-201 now has power - by Joeztech - 12-27-2013, 07:28 AM
RE: 40-201 now has power - by Joeztech - 12-28-2013, 01:28 PM
RE: 40-201 now has power - by Joeztech - 12-28-2013, 05:36 PM
RE: 40-201 now has power - by codefox1 - 12-29-2013, 08:30 PM
RE: 40-201 now has power - by morzh - 12-29-2013, 08:42 PM
RE: 40-201 now has power - by Joeztech - 12-30-2013, 07:17 AM
RE: 40-201 now has power - by Joeztech - 12-30-2013, 07:30 AM
RE: 40-201 now has power - by Joeztech - 12-31-2013, 06:33 PM
RE: 40-201 now has power - by jerryhawthorne - 12-31-2013, 07:54 PM
RE: 40-201 now has power - by Joeztech - 02-19-2014, 08:05 PM
Users browsing this thread: 14 Guest(s)
There are currently 10201 online users. [Complete List]
» 3 Member(s) | 10198 Guest(s)
