40-201 Output Xfmr Issues
Mondial;
You were exactly right, the phasing was positive instead of negative. Once I reversed the speaker connections and the feedback connections at the transformer secondary the oscillation went away. Just reversing the speaker leads eliminated the mid-frequency feedback oscillation but then I had low frequency motor-boating oscillation that varied with the tone control. Then reversing the connections of the end points of the resistive feedback network eliminated the motor-boating. The key was that just grounding the feedback lead to the volume/tone control stopped all oscillations. Now the radio is silent when it should be and I can go on with troubleshooting and alignment!
Joe
40-201 Output Xfmr Issues - by Joeztech - 12-14-2013, 06:14 PM
RE: 40-201 Output Xfmr Issues - by morzh - 12-14-2013, 06:24 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-14-2013, 08:08 PM
RE: 40-201 Output Xfmr Issues - by Ron Ramirez - 12-14-2013, 08:20 PM
RE: 40-201 Output Xfmr Issues - by morzh - 12-14-2013, 08:23 PM
RE: 40-201 Output Xfmr Issues - by Ron Ramirez - 12-14-2013, 08:25 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-15-2013, 07:37 AM
RE: 40-201 Output Xfmr Issues - by Mondial - 12-15-2013, 01:55 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-16-2013, 05:03 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-22-2013, 11:49 AM
RE: 40-201 Output Xfmr Issues - by codefox1 - 12-23-2013, 04:03 PM
RE: 40-201 Output Xfmr Issues - by Mondial - 12-23-2013, 05:57 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 08:21 AM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 09:48 AM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 05:19 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 08:22 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 01-08-2014, 08:41 AM
RE: 40-201 Output Xfmr Issues - by codefox1 - 01-08-2014, 09:27 PM
Philco 91 Tuning Condenser
There are currently 10214 online users. [Complete List]
» 3 Member(s) | 10211 Guest(s)
