40-201 Output Xfmr Issues
I found and corrected the problem I discovered as I was attempting IF alignment. I had the 1st. IF transformer secondary and tertiary windings swapped. I found it doing an ohm meter check. The secondary winding has about an 8-10 ohm resistance and the tertiary winding has less than 0.1 ohms resistance. I connected them to the correct points and the set quickly came into alignment. I found that with just this portion of alignment done, I already am getting signals on all bands and the push-buttons work but need adjusting for some local stations. This radio lives again!
Tomorrow or so I will get around to doing a complete alignment. For now I am happy. Christmas came early here!
Merry Christmas and a Happy, Healty and Prosperous New Year!
Joe
40-201 Output Xfmr Issues - by Joeztech - 12-14-2013, 06:14 PM
RE: 40-201 Output Xfmr Issues - by morzh - 12-14-2013, 06:24 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-14-2013, 08:08 PM
RE: 40-201 Output Xfmr Issues - by Ron Ramirez - 12-14-2013, 08:20 PM
RE: 40-201 Output Xfmr Issues - by morzh - 12-14-2013, 08:23 PM
RE: 40-201 Output Xfmr Issues - by Ron Ramirez - 12-14-2013, 08:25 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-15-2013, 07:37 AM
RE: 40-201 Output Xfmr Issues - by Mondial - 12-15-2013, 01:55 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-16-2013, 05:03 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-22-2013, 11:49 AM
RE: 40-201 Output Xfmr Issues - by codefox1 - 12-23-2013, 04:03 PM
RE: 40-201 Output Xfmr Issues - by Mondial - 12-23-2013, 05:57 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 08:21 AM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 09:48 AM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 05:19 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 12-24-2013, 08:22 PM
RE: 40-201 Output Xfmr Issues - by Joeztech - 01-08-2014, 08:41 AM
RE: 40-201 Output Xfmr Issues - by codefox1 - 01-08-2014, 09:27 PM
Philco 91 Tuning Condenser
There are currently 6883 online users. [Complete List]
» 2 Member(s) | 6881 Guest(s)
