509X Registry?
Are there any other owners of the Philco 509X out there? I've been talking to an owner in KY recently; we're both looking to learn as much as possible about these sets and maybe find some copies of any literature we can find.
Thanks in advance!
509X Registry? - by theblurrrr - 05-18-2008, 04:51 PM
