40-201 now has power
If you still have any old caps in there, you really should replace them before powering the set up again. That tone control should be your ultimate clue that all the caps are bad. This is likely what is causing your start-up crackling. This could also be caused by a noisy resistor.
40-201 now has power - by Joeztech - 12-23-2013, 03:45 PM
RE: 40-201 now has power - by jerryhawthorne - 12-23-2013, 04:27 PM
RE: 40-201 now has power - by Joeztech - 12-23-2013, 06:45 PM
RE: 40-201 now has power - by jerryhawthorne - 12-23-2013, 07:13 PM
RE: 40-201 now has power - by Joeztech - 12-23-2013, 08:08 PM
RE: 40-201 now has power - by codefox1 - 12-23-2013, 08:56 PM
RE: 40-201 now has power - by jontz - 12-23-2013, 09:33 PM
RE: 40-201 now has power - by Paul Philco322 - 12-23-2013, 11:11 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 07:33 AM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 07:45 AM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 10:14 AM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 04:53 PM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 05:53 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 08:03 PM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 08:53 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 10:54 PM
RE: 40-201 now has power - by Radioroslyn - 12-25-2013, 11:15 AM
RE: 40-201 now has power - by Joeztech - 12-25-2013, 03:34 PM
RE: 40-201 now has power - by BrendaAnnD - 12-25-2013, 06:47 PM
RE: 40-201 now has power - by Joeztech - 12-25-2013, 07:05 PM
RE: 40-201 now has power - by Joeztech - 12-26-2013, 08:15 AM
RE: 40-201 now has power - by hsusmann - 12-26-2013, 09:53 AM
RE: 40-201 now has power - by Joeztech - 12-26-2013, 11:48 AM
RE: 40-201 now has power - by hsusmann - 12-26-2013, 10:54 PM
RE: 40-201 now has power - by BrendaAnnD - 12-26-2013, 11:59 PM
RE: 40-201 now has power - by Eric Adams - 12-27-2013, 01:50 AM
RE: 40-201 now has power - by Joeztech - 12-27-2013, 07:28 AM
RE: 40-201 now has power - by Joeztech - 12-28-2013, 01:28 PM
RE: 40-201 now has power - by Joeztech - 12-28-2013, 05:36 PM
RE: 40-201 now has power - by codefox1 - 12-29-2013, 08:30 PM
RE: 40-201 now has power - by morzh - 12-29-2013, 08:42 PM
RE: 40-201 now has power - by Joeztech - 12-30-2013, 07:17 AM
RE: 40-201 now has power - by Joeztech - 12-30-2013, 07:30 AM
RE: 40-201 now has power - by Joeztech - 12-31-2013, 06:33 PM
RE: 40-201 now has power - by jerryhawthorne - 12-31-2013, 07:54 PM
RE: 40-201 now has power - by Joeztech - 02-19-2014, 08:05 PM
