Pulled out my 37-650 tonight
Just pulled out an old 37-650 I've owned for years but
never got to. Been in the back of my basement all this
time.
Looks like a hard radio to work on, with some paper
caps buried deep under some trimmer caps in the
center section.
I saw one older thread here about a 37-650 and
it didn't seem like it took much to get it working.
I will need a new dial piece and also the speaker
is totally shot.
I'm trying to figure out if I should just scrap the
radio or give it a try. Cabinet is not too bad.
Will post some pictures soon.
Anyone out there have any advice?
Thanks!
Herb S.
Ithaca NY
Pulled out my 37-650 tonight - by hsusmann - 12-26-2013, 12:35 AM
RE: Pulled out my 37-650 tonight - by morzh - 12-26-2013, 11:17 AM
RE: Pulled out my 37-650 tonight - by AI2V - 12-26-2013, 12:14 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-26-2013, 10:46 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 09:44 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 09:55 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:00 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:00 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:04 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:12 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:13 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:18 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:22 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:30 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 11:37 PM
RE: Pulled out my 37-650 tonight - by Ron Ramirez - 12-30-2013, 01:06 PM
RE: Pulled out my 37-650 tonight - by Joe Rossi - 12-30-2013, 10:01 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-31-2013, 12:40 AM
RE: Pulled out my 37-650 tonight - by BrendaAnnD - 12-31-2013, 02:24 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-31-2013, 09:53 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-05-2014, 02:42 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-05-2014, 10:12 PM
RE: Pulled out my 37-650 tonight - by codefox1 - 01-05-2014, 11:28 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-06-2014, 09:40 AM
RE: Pulled out my 37-650 tonight - by Eric T - 01-10-2014, 08:04 PM
RE: Pulled out my 37-650 tonight - by Jamie - 01-11-2014, 10:52 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-11-2014, 11:57 AM
Philco 91 Tuning Condenser
There are currently 9182 online users. [Complete List]
» 1 Member(s) | 9181 Guest(s)
