Picked Up A Grundig Last Night
I picked up a Model 88 off eBay which is a smaller AM/FM unit. I think it only has 4 tubes and it is one of my best performing units of the lot. I listen to it quite often. Does yours have a Magic Eye? Nice find! Enjoy!
Craig R.
Picked Up A Grundig Last Night - by Geoff - 12-27-2013, 01:27 PM
RE: Picked Up A Grundig Last Night - by VntgRads - 12-27-2013, 01:36 PM
RE: Picked Up A Grundig Last Night - by morzh - 12-27-2013, 02:06 PM
RE: Picked Up A Grundig Last Night - by TA Forbes - 12-27-2013, 02:37 PM
RE: Picked Up A Grundig Last Night - by morzh - 12-27-2013, 04:01 PM
RE: Picked Up A Grundig Last Night - by Geoff - 12-27-2013, 05:21 PM
RE: Picked Up A Grundig Last Night - by morzh - 12-27-2013, 06:28 PM
RE: Picked Up A Grundig Last Night - by VntgRads - 12-27-2013, 06:40 PM
RE: Picked Up A Grundig Last Night - by morzh - 12-28-2013, 10:23 PM
RE: Picked Up A Grundig Last Night - by Arran - 12-29-2013, 12:53 AM
RE: Picked Up A Grundig Last Night - by Joeztech - 01-02-2014, 12:40 PM
