This Was In My Xmas Card!
Thanks to all for the valuable information. I have one more question. If I just want to clean the cabinet and not harm the existing finish, what product(s) are recommended these days. I figure if I give it a good cleaning, I can better ascertain just what needs to be done to the cabinet. Thanks, in advance, for your input.
Craig R.
This Was In My Xmas Card! - by VntgRads - 12-27-2013, 03:02 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 03:04 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 03:17 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 03:39 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 03:58 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 04:27 PM
RE: This Was In My Xmas Card! - by Jayce - 12-27-2013, 04:33 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 06:08 PM
RE: This Was In My Xmas Card! - by Ron Ramirez - 12-27-2013, 06:15 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 06:21 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 06:46 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 07:45 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 08:18 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 09:29 PM
RE: This Was In My Xmas Card! - by Jamie - 12-27-2013, 09:51 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 10:06 PM
RE: This Was In My Xmas Card! - by EricS - 12-27-2013, 10:20 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 10:45 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 11:12 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-27-2013, 11:28 PM
RE: This Was In My Xmas Card! - by jerryhawthorne - 12-27-2013, 11:32 PM
RE: This Was In My Xmas Card! - by TA Forbes - 12-28-2013, 10:56 AM
RE: This Was In My Xmas Card! - by Gene Pederson - 12-28-2013, 08:31 PM
RE: This Was In My Xmas Card! - by VntgRads - 12-28-2013, 11:17 PM
RE: This Was In My Xmas Card! - by TA Forbes - 12-29-2013, 11:16 AM
RE: This Was In My Xmas Card! - by LASJayhawk - 12-29-2013, 12:57 PM
Philco 91 Tuning Condenser
